2024-12-27 1:43 AM
We want to use iio buffers to read accelerometer data. I tried the following, but it did not work.
root@FAFUSION:/sys/bus/iio/devices/iio:device2# ls
buffer current_timestamp_clock events in_accel_scale_available in_accel_y_raw mount_matrix of_node sampling_frequency scan_elements uevent
buffer0 dev in_accel_scale in_accel_x_raw in_accel_z_raw name power sampling_frequency_available subsystem waiting_for_supplier
root@FAFUSION:/sys/bus/iio/devices/iio:device2# cat name
ism330dhcx_accel
root@FAFUSION:/sys/bus/iio/devices/iio:device2# echo 1 > scan_elements/in_accel_x_en
root@FAFUSION:/sys/bus/iio/devices/iio:device2# echo 1 > scan_elements/in_accel_y_en
root@FAFUSION:/sys/bus/iio/devices/iio:device2# echo 1 > scan_elements/in_accel_z_en
root@FAFUSION:/sys/bus/iio/devices/iio:device2# echo 1 > buffer0/in_accel_x_en
root@FAFUSION:/sys/bus/iio/devices/iio:device2# echo 1 > buffer0/in_accel_y_en
root@FAFUSION:/sys/bus/iio/devices/iio:device2# echo 1 > buffer0/in_accel_z_en
root@FAFUSION:/sys/bus/iio/devices/iio:device2# echo 1 > scan_elements/in_timestamp_en
root@FAFUSION:/sys/bus/iio/devices/iio:device2# echo 1 > buffer0/in_timestamp_en
root@FAFUSION:/sys/bus/iio/devices/iio:device2# echo 833 > sampling_frequency
root@FAFUSION:/sys/bus/iio/devices/iio:device2# echo 1 > buffer/enable
root@FAFUSION:/sys/bus/iio/devices/iio:device2# echo 1 > buffer0/enable root@FAFUSION:/sys/bus/iio/devices/iio:device2# cat buffer0/*
0
in
1
1
0
le:s16/16>>0
1
1
le:s16/16>>0
1
2
le:s16/16>>0
1
3
le:s64/64>>0
1024
1
root@FAFUSION:/sys/bus/iio/devices/iio:device2# iio_readdev ism330dhcx_accel accel_x accel_y accel_z timestamp
WARNING: High-speed mode not enabled
Unable to refill buffer: Connection timed out (110)What is the correct way of using 'libiio' to read the accelerometer data
2025-01-10 8:51 PM
Hi @Federica Bossi ,
The link you have provided has drivers which we are already using as part of the Mickledore distribution but it does not provide any user-space application examples to read the sensor using IIO.
Anyway, we have been able to write our own application that pulls the data out of the FIFO at a good rate.
2025-01-02 11:38 PM
Hi @Sharat_Rao ,
Have you already looked at our official drivers and examples on Github?
Hope this helps!
2025-01-10 8:51 PM
