LSM303 register interface compatibility ...
2025-01-14 4:27 AM
I recently began working on an driver software for a magnetometer application, which is intended to support both the LSM303 (the LSM303DLHC, to be exact), and the HMC5883L from Honeywell.
And I didn't fail to notice that both devices have identical I2C addresses and identical values for the identification register values (IRA, IRB and IRC).
My question would be, is this intentional ?
Not that it is of utmost importance to me, I found another way to distinguish between both. The HMC5883 has no accelerometer part, and when I can write into a RW accelerometer config register and read the same value back, I deal with a LSM303, else with a HMC5883.
E-Compasses
2025-01-14 4:39 AM
@Ozone wrote:My question would be, is this intentional ?
More likely accidental, I should think.
They are devices from two different manufacturers - I doubt the designers from either company go around checking all competitor's parts ...
2025-01-14 7:06 AM
That got me wondering.
And not only the I2C adress and ID register values are the same, the internal addresses of those registers as well.
Meaning, you send a I2C read request with the same register offset, and get identical answers from both devices.
I think this is no coincidence, one wanted to be compatible with the other, I guess.
Although I don't expect a full disclosure here ...
2025-01-14 7:15 AM - edited 2025-01-14 7:15 AM
So are any/all of the other registers compatible, too?
2025-01-15 2:17 AM
LSM303 :
And HMC5883L:
The LSM303 has an additional accelerometer, and those registers are located at higher addresses.
The magnetometer section of both is so far identical - although some parameters are not, it seems.
At least the maximal update rate of the magnetometer data is different (200Hz vs. 75Hz).
I suppose someone licensed someone else's IP here, and integrated it into his own device.
Keeping all ID data identical seems strange to me, though.
2025-01-16 12:26 AM
And, there is this peculiar statement in the datasheet (DocID018771 Rev 2) :
There is just one I2C interface presented to the outside, one SDA and one SCL pin.
