2012-07-05 05:55 AM
2012-07-10 04:00 AM
Hi guys,
I have found the solution for this.In the application note CTRL_REG3 is metioned as the register to configure interruppt on INT1 pin but the correct configuration is use CTRL_REG6 bit 7 and bit 6(I2_CLICKen and I2_INT1) will enable tap and double tap interruppts on INT2 pin.(Tip:for tuning increase sampling rate (CTRL-REG1) increase time-limit value).2012-11-07 01:38 AM
