2024-09-25 10:10 AM
1) What capacitance does the LIS2DW12TR introduce to the I2C bus lines?
2) What is it's maximum bus capacitance threshold in normal I2C mode (100khz)?
The datasheet doesn't have info on either of these points. It only quotes that the max bus capacitance in fast/high-speed mode.
Help here would be great as I'm calculating the RC constant on my I2C lines, as I think they're causing I2C to not work!
Thanks!
