I3C interfacing of LSM6DSOX
Options
2022-06-08 2:30 AM
I'm working on LSM6DSOX with our custom ARM Cortex M4 core with I3C master.
I have few doubts as follow
- Does LSM6DSOX retain the Dynamic slave address after ENTDAA procedure? I'm unable to assign another dynamic address after initial assignment is done.
- SDR mode of LSM6DSOX supports upto 12.5MHz? I'm seeing a variable clock frequency on I3C bus as attached for SETDASA process. will this be a problem? I'm not getting ACK for the assigned Dynamic address when Static address is provided
0 REPLIES 0
