2019-07-11 10:28 PM
Hello everyone,
I want to receive humidty from SHT21 sensor. I received first or a few data and then this communication stop. Why? Can you help me please ?
http://www.farnell.com/datasheets/1780639.pdf this is datasheet of SHT21
Thank you
2019-07-18 8:12 AM
Hi @kadir üstün , did you check the I2C pattern with an oscilloscope or a pattern analyzer? You should take care of pull-up values and of Vdd/VddIO range, but I suggest you to directly check the issue with Sensirion company support. Regards
