2024-12-23 12:50 AM
I am currently working on modifying the sampling rate for the LSM6DSO32G IMU sensor in a Samsung Android kernel. After reviewing the device tree and sensor driver files, I noticed that certain parameters like odr (output data rate) seem to control the sampling rate. However, I am not sure of the exact steps to apply these changes and ensure that the modified sampling rate is reflected correctly in the system.
Here are my specific questions:
Any guidance, code examples, or references to related documentation would be greatly appreciated!
Thank you in advance for your help.
Best regards,
2024-12-23 2:28 AM
You need to go to a suitable (Samsung) Android developer's forum - none of this has anything to do with ST.
