2024-09-04 07:38 AM
hi!
I have a problem with the calibration of the IIS2ICLX-Accelerometer. I see there is happening a calibration but because I make a sensor fusion in the next step, I want to have the calibration fixed once its done. In the data-sheet and the forum I couldnt find a solution. Is there a possibility to manually control the background calibration process?
Thanks!
