2021-03-22 10:46 PM
reference : https://www.st.com/resource/en/data_brief/vl53l1x-satel.pdf
As you can see, I have the names of the pins from the data sheet but I don't know which is pin 1 or pin 2 and so on
2021-03-23 2:52 AM
We are very sorry that this cannot be seen from the circuit. Pin 1 is the square pad of J1, pin 2 is the first pin of the second row next to it (see picture below):
Good luck!
/Peter
2021-03-23 2:52 AM
Good luck!
/Peter
2021-03-23 3:03 AM
Thank you so much
