Hi, I am working with LIS2DE12 accelerometer, I want detect any new data is updated to temperature and x,y,z axis registers.can any one provide steps for configuration.
Malepu Narendhar
Posted on July 18, 2017 at 10:45
4 REPLIES 4
Miroslav BATEK
Posted on July 18, 2017 at 11:04
You should set bit I1_ZYXDA in CTRL_REG3 register. With this settings the interrupt pin INT1 is triggered when new data are available.
If you can't use INT1 pin you can continuously read ZYXDA bit in STATUS_REG register which give you the same information.
Posted on July 18, 2017 at 11:52
Thanks for your reply.
Posted on July 18, 2017 at 11:53
how does self test mode will work.
Legacy member
Not applicable
