2020-01-20 7:33 AM
Hi, I am using LSM6DS3TR-C sensor. In my application, I require two buffers to store MEMS samples. One buffer contains data before the event and second buffer after the event.
Currently, I am using continuous-to-FIFO mode for my application and two interrupts, FIFO_threshold and single_tap. When I enable both interrupts, I get data continuously from the sensor and this is useful for first buffer but on tap_interrupt, I do not have any data for second buffer. Moreover, when using only tap_interrupt, I get data after tap interrupt for second buffer but cannot get data for the first buffer.
Using continuous-to-FIFO mode, I would like to update my first buffer continuously and during interrupt, I would like to switch to FIFO mode to store data after the interrupt event.
I have attache the code below;
error = lsm6ds3tr_c_fifo_wtm_flag_get(&lsm6ds3, &waterm);
kal_prompt_trace(MOD_ABM,"001 error:%d, waterm:%d", error,waterm);
if(error!=STATUS_OK) return STATUS_FAIL;
if(waterm){
error = lsm6ds3tr_c_fifo_data_level_get(&lsm6ds3, &num);
kal_prompt_trace(MOD_ABM,"002 error:%d, num:%d", error,num);
if(error!=STATUS_OK) return error;
num_pattern = num/pattern_len;
kal_prompt_trace(MOD_ABM,"003 num_pattern:%d, pattern_len:%d", num_pattern,pattern_len);
while (num_pattern-- > 0){
if(all_source.tap_src.single_tap){
lsm6ds3tr_c_fifo_raw_data_get(&lsm6ds3, data_raw_angular_rate.u8bit, 3*sizeof(int16_t));
kal_prompt_trace(MOD_ABM,"004 num_pattern:%d, data_raw_angular_rate.i16bit:%x %x %x", num_pattern, angular_rate_mdps[0],angular_rate_mdps[1],angular_rate_mdps[2]);
*angular_rate_mdps = lsm6ds3tr_c_from_fs250dps_to_mdps(data_raw_angular_rate.i16bit[0]);
*(angular_rate_mdps+1) = lsm6ds3tr_c_from_fs250dps_to_mdps(data_raw_angular_rate.i16bit[1]);
*(angular_rate_mdps+2) = lsm6ds3tr_c_from_fs250dps_to_mdps(data_raw_angular_rate.i16bit[2]);
lsm6ds3tr_c_fifo_raw_data_get(&lsm6ds3, data_raw_acceleration.u8bit, 3*sizeof(int16_t));
kal_prompt_trace(MOD_ABM,"004 num_pattern:%d, data_raw_acceleration.i16bit:%x %x %x", num_pattern, acceleration_mg[0], acceleration_mg[1], acceleration_mg[2]);
*acceleration_mg = lsm6ds3tr_c_from_fs2g_to_mg(data_raw_acceleration.i16bit[0]);
*(acceleration_mg+1) = lsm6ds3tr_c_from_fs2g_to_mg(data_raw_acceleration.i16bit[1]);
*(acceleration_mg+2) = lsm6ds3tr_c_from_fs2g_to_mg(data_raw_acceleration.i16bit[2]);
acc_x_buffer_b[num_pattern]= acceleration_mg[0];
acc_y_buffer_b[num_pattern]= acceleration_mg[1];
acc_z_buffer_b[num_pattern]= acceleration_mg[2];
gyro_x_buffer_b[num_pattern]= angular_rate_mdps[0];
gyro_y_buffer_b[num_pattern]= angular_rate_mdps[1];
gyro_z_buffer_b[num_pattern]= angular_rate_mdps[2];
kal_prompt_trace(MOD_ABM,"BufB_No: %d, ACC: %d %d %d, GYR: %d %d %d", num_pattern, acc_x_buffer_b[num_pattern], acc_y_buffer_b[num_pattern], acc_z_buffer_b[num_pattern], gyro_x_buffer_b[num_pattern], gyro_y_buffer_b[num_pattern], gyro_z_buffer_a[num_pattern]);
else{
kal_prompt_trace(MOD_ABM,"004 num_pattern:%d, data_raw_angular_rate.i16bit:%x %x %x", num_pattern, angular_rate_mdps[0], angular_rate_mdps[1], angular_rate_mdps[2]);
acc_x_buffer_a[num_pattern]= acceleration_mg[0];
acc_y_buffer_a[num_pattern]= acceleration_mg[1];
acc_z_buffer_a[num_pattern]= acceleration_mg[2];
gyro_x_buffer_a[num_pattern]= angular_rate_mdps[0];
gyro_y_buffer_a[num_pattern]= angular_rate_mdps[1];
gyro_z_buffer_a[num_pattern]= angular_rate_mdps[2];
kal_prompt_trace(MOD_ABM,"BufA_No: %d, ACC: %d %d %d, GYR: %d %d %d", num_pattern, acc_x_buffer_a[num_pattern], acc_y_buffer_a[num_pattern], acc_z_buffer_a[num_pattern], gyro_x_buffer_a[num_pattern], gyro_y_buffer_a[num_pattern], gyro_z_buffer_a[num_pattern]);
kal_prompt_trace(MOD_ABM,"angular_rate_mdps:%x %x %x, acceleration_mg:%x %x %x", angular_rate_mdps[0], angular_rate_mdps[1], angular_rate_mdps[2], acceleration_mg[0], acceleration_mg[1], acceleration_mg[2]);
lsm6ds3tr_c_fifo_mode_set(&lsm6ds3, LSM6DS3TR_C_BYPASS_MODE);
lsm6ds3tr_c_fifo_mode_set(&lsm6ds3, LSM6DS3TR_C_STREAM_TO_FIFO_MODE);Could you please advice me on this application?
Kind regards,
Aakash Soni.
2020-01-23 8:37 AM
Please ignore this question and see my updated question here, https://community.st.com/s/question/0D50X0000C0yMlpSQE/how-do-i-switch-between-streamtofifo-and-stream-mode-for-lsm6ds3trc.
