Do you have example (or possibly some documents) of implementing random tree forest on the ML core of the sensor?
‎2023-02-17 5:32 AM
Q&A - webinar "Anyone can build smarter applications with this intelligent IMU"
INEMO-Inertial Modules
‎2023-02-17 6:00 AM
It is not possible to use random tree forest algorithms with the MLC. In the Machine Learning Core (MLC) only the decision tree algorithms work. If you want to start developing your MLC algorithm, it is advised to follow the design tip: DT0139
‎2023-02-17 6:00 AM
