Current consumption of LSM6DS3
2020-05-06 10:55 PM
I would like to know the current consumption of a LSM6DS3 with it's accelerometer and gyroscope running at 52 Hz and 104 Hz. The LSM6DS3 will be powered by a 2.8V source. Are there any official numbers or documents available for this?
2020-05-06 11:46 PM
Hi @GTS.1 , I can share you some characterization (lab) data on 30 samples, for Vdd = 2.5V (so for 2.8V the current consumption will be a little bit higher):
- Axl and gyro ODR = 52Hz
- Low Power mode
- High performance mode
- Axl and gyro ODR = 104Hz
- Low Power mode
2020-05-06 11:46 PM
- Low Power mode
- Low Power mode
2020-05-13 4:15 AM
Thanks for the quick reply!
