Change ODR on SensorTile
CRoma.11
I programmed the sensorTile STEVAL-STLKT0V1 with ALLMEMS1 end I used STM32CubeIDE with NUCLEO32.
How I can change the sampling frequency (ODR) of accelerometers and gyroscopes?
Thanks,
Chiara
12 REPLIES 12
CRoma.11
Thank you very much for the useful advice.
Best Regards,
Chiara
@CRoma.1​
you're welcome =)
just as a reminder, if you "select a best answer" in this thread you can help other community members with a similar question
Niccolò
DAlta.1
Good Evening,
I have the same problem as Chiara. I would set a sample rate of 100Hz or higher. If I wanted to modify ALLMEMS1 firmware to do that (perhaps telling that from the app and saving results on the SensorTile SD ), how would I do?
