2021-03-03 08:19 AM
2021-03-03 09:29 AM
MLC and FSM can't use natively user calibrated data, but, since the configuration of both MLC & FSM are loaded at the power-up of the device from an external host, the external host can modify/adapt the configuration to each single device based on user calibration data
2021-03-03 09:29 AM
