Basic Functioning and UNICO
Options
2019-01-11 1:53 AM
Hi
I am new to this lsm6dso
i am currently using STEVAL-MKI109V3 with STEVAL-MKI191V1 using unico.
What i a getting is that "ADAPTER BOARD NOT SUPPORTED"
I has also tried Serial Terminal still getting same result with *setdb191v1
any help with this?
Labels:
INEMO-Inertial Modules
1 REPLY 1
Options
2019-01-11 7:00 AM
Can you please update the firmware in your board. You need the firmware which is distributed in the STSW-MKI109W together with the Unico.
Please check the directory DFU and the UM0412 - DFU User Guide.pdf for instruction how to update the FW.
