ASM330LHB chip shows large gyro bias jumps during temperature cycling (-40°C to 100°C)
2024-02-06 1:21 AM
I performed a temperature cycle check on the ASM330LHB chip. Relative to the warming process (red curve), during the cooling process (blue curve), it is prone to large zero-bias jumps (in the red box of the picture)。
The jump during the cooling process, I feel like there is a correction mechanism in the gyro in the chip, which recognizes a large shift in the gyro zero bias during the cooling process, and then immediately corrects the large zero bias shift.
Can you please help explain what causes this?
Note: These data on the image have been smoothed for 10 seconds.
Gyroscopes
MEMS-Studio
2024-02-07 3:24 AM - edited 2024-02-07 3:25 AM
Hi @dayu ,
That's very strange. Can you give me more details about your setup and your test?
Thanks.
2024-02-07 3:57 AM
We are putting 2 IMU chips on the same PCB. The temperature is lowered from about 30°C to -40°C, then raised from -40°C to 100°C, and then lowered from 100°C to about 30°C. The temperature is lowered at a rate of 1°C/min. The temperature is raised and lowered at a rate of 1°C/min. During the cooling process, large gyro bias jumps are likely to occur.
2024-02-09 12:43 AM
Hi @dayu ,
It could be something related to the soldering process that causes some stress to the mems.
2024-02-15 11:33 PM
But why does this large gyro bias jump only occurs during the cooling process and not during the warm up process?
2024-03-01 7:06 AM
Hi @dayu ,
I think it's chance, you might see it heating as well as cooling.
