2023-05-17 01:28 AM
2023-05-17 01:58 AM
Hi @KKots.1 ,
Welcome to ST Community!
You can look at our examples on Github that you can find at this link.
If my reply answered your question, please click on Select as Best at the bottom of this post. This will help other users with the same issue to find the answer faster 🙂
2023-05-17 01:58 AM
Hi @KKots.1 ,
2023-05-17 04:37 AM
Hello Federica,
Thank you for the reply.
What I'm also trying to understand is the values of the registers. For some of them, the default value is given in binary form on the datasheet. For others, the value is just "output". How should I understand this?
2023-05-17 06:03 AM
Ciao @KKots.1 ,
When the Datasheet reports just "output" is because the register is only Read, instead when the register is R/W the value is given in binary.
If my answers help you, please mark my answer as "Best Answer" by clicking on the "Select as Best" button, this can be helpful for Community users to find this solution faster.
