2021-08-10 01:51 AM
I'm in the process of some development using ST's AIS1120SX Accelerometer, in conjunction with a Nucleo L432-KC development board. I thought I would share some tips and suggestions I have about the accelerometer, as I found it particularly difficult to get started with.
If you have any issues, I can try to help, but hopefully this post can clear things up for the next person to try and use this sensor.
Cheers :)
2021-08-11 05:41 PM
Hi @Eleon BORLINI,
Can you clarify what you need me to write in the comments?
Cheers,
Cooper
2021-08-11 06:00 AM
Hi @CJeff.1 ,
Thank you very much for your "Tops and Suggestions" reporting.
I confirm you that your guess are correct, and I'll report the considerations internally to the relevant people.
In order to highlight your post, please comment this below so that I can mark you answer as "Best".
Thank you again,
-Eleon
2021-08-11 05:41 PM
Hi @Eleon BORLINI,
Cheers,
Cooper
2021-08-12 02:47 AM
Hi Cooper,
that's enough, my intention was to mark a comment from you as BA so that the question can have more visibility.
Thank you again,
-Eleon
