1. Does the MotionDI library output the gravitational acceleration along with linear acceleration as I am getting it in the lin acc. data?
2. How to wipe out the effect of gravitational acceleration in linear acceleration?
Sensortile kit is used.
Options
2022-03-01 9:08 AM
Sensortile kit is used and linear acceleration is fused output from gyroscope and accelerometer,the sensor is kept with z-axis of accelerometer being parallel to gravity (screenshot attached).
1 REPLY 1
Options
2022-03-08 8:35 AM
Hi @MAhm.1,
As far as I know the linear acceleration output from MotionDI should be without gravitational acceleration. Could you please send me your datalog that would include timestamp, acc & gyr & mag data and your calculated results? Attached is the example of the datalog format that would help a lot.
