STWPLLSim run error
EP Pang
Posted on March 14, 2018 at 10:23
I am using STWPLLSim tool to simulate loop values for STW81200. After installing, when I start the program the following LIBRARY NOT FOUND error occurs:
java.lang.UnsatisfiedLinkError: C:lProg ram Files (x86)1STMicroelectronicsISTWaLSim_v5.31Loaderltimeresp.d11: Can't find dependent libraries
Anybody has solve this problem?
1 REPLY 1
ngodoanvan
Senior
Do you solve this problem ?
