2019-04-22 4:46 AM
In the STW81200 it is written that the second VCO output can be set to work in-phase or in quadrature to the primary one.
In the control registers I can not find a field that is responsible for that option. How should I configure the IC to have second VCO output working in quadrature in respect to primary one?
Thank you in advance and best regards,
Krzysztof
