Visitor II
December 23, 2024
Specs for EXTVCO_IN for STW81200
  • December 23, 2024
  • 1 reply
  • 446 views
Both STuW81300 and STW81200 have the option of using an external VCO but the inputs characteristics aren't specified anywhere. What is the input frequency range, input power/sensitivity in dBm or 50ohm match for single-ended input? There is one application diagram showing VCO output with a coupling capacitor followed by a balun. Can we just ac ground the other pin instead of a balun?
1 reply
Peter BENSCH
Welcome @mallets, to the community!
The Community is not a technical support team, but a peer-to-peer forum (see Terms and Conditions, article 2 etc). As it is very likely that no community user will be able to help you, please ask your questions again to your local distributor or to the personal Online Support OLS.
/Peter
