2016-02-04 02:02 PM
I have two SP1ML modules, transmitting 11 dBm. If they are really close (1 cm), the RSSI is around -30 dBm, when the distance is 1 m, the RSSI goes down to -90 dBm.
It seems that these values are too low. Anyone can help?2017-03-21 01:46 AM
hi, were you able to work this out? what is the range of communication that you got?
