2018-08-13 06:18 AM
I have a custom design based on the S2-LP eval kit, tested my firmware (based on the ST Sigfox Library) with the eval kit and ST's ID/PAC and all is working fine. Custom hardware is also working fine and now I am in the process of installing the prototype credentials for my custom hardware.
I applied for the credentials at sigfox (pre-verified prototypes) and got the id_pac.txt, id_key.bin and key and was trying to follow the procedure as described here: https://build.sigfox.com/steps/development#network-credentials ...but I cannot understand what do I need to do exactly to generate the data that I need to put in the eeprom.
That page mentions an AESd tool but I cannot find it anywhere on the sigfox site.
Any guidance please? I'm stuck
Thanks,
George
2018-08-24 02:02 AM
You have to use the application from UM2169 to load the credentials.
The sigfox lib of ST looks to be a closed source demo.
