2024-10-23 10:24 AM - last edited on 2025-02-03 6:59 AM by Peter BENSCH
Could someone help to understand the better value to use at frequency deviation, considering at bellow specs:
#define BASE_FREQUENCY 916000000 //Hz #define MODULATION_SELECT MOD_2GFSK_BT05 #define DATARATE 38400 //bps #define FREQ_DEVIATION ????? #define BANDWIDTH 100000 //Hz
#define CHANNEL_SPACE 180000 //Hz
A higher frequency deviation means that easier to read data from another devices (if frequency of devices drift)?
Best regards
Leonardo
