2024-02-18 08:57 PM
I am currently designing a PCB with bluenrg332AC and need the layout / Gerber file to make progress. But I couldn't find any on the Internet, so can anyone provide me with the file or give me some hint of finding the file? Thank you!
2024-02-19 02:34 AM
You will find information in AN5526 (PCB design guidelines for the BlueNRG-LP, BlueNRG-LPS devices), as well as in the evaluation boards STEVAL-IDB012V1 or STEVAL-IDB013V1.
Hope that helps?
/Peter
2024-02-19 02:34 AM
Hope that helps?
/Peter
2024-02-19 02:40 AM
@JasonYang wrote:I am currently designing a PCB with bluenrg332AC and need the layout / Gerber file to make progress
What do you mean by that?
If you are designing a PCB, that means that you are creating the layout!
And the Gerber file will be the output from your PCB tool when you have created that layout.
