L9663
JL1
Direct interface of communication interface Is the transceiver directly connected to the PSI5 interface of the ECU
1 REPLY 1
SCONI.8
In Mode2 configuration, L9663 Doutx pins output the Manchester-encoded voltage signal of the received sensor(s) data transmission. You should verify the MCU peripheral requirements (and configuration) for the connection details.
