Could not connect to the BlueNRG-2 in a single attempt
MVinn.1
I'm using BLE_SensorDemo project. I have created my own services. Everything works fine reading and writing the data. The only problem is, when I try to connect from my Android mobile, I could not connect to to the BlueNRG-2 in first attempt. I had to make several attempts to establish the connection.
I see the device is in discoverable mode only. I could not figure out the issue. I hope someone will help me out. Thank you in advance.
0 REPLIES 0
