Application note for L9663 PSI5 transceiver
‎2019-05-28 2:11 AM
Is there any possibility to have application note of a communication between a microcontroller and a sensor (magnetic angular position sensor in my case) using a l9663 transceiver. I'm a bit lost with all the infomation in the datasheet and I need a exemple.
‎2021-08-19 2:27 AM
Hi, do you find the answer? I have a similar application case. Going throuhg the datasheet, I think L9663 doesn't support a slave function at the sensor end.
‎2021-08-19 6:53 PM
Please check: AN5366 L9663 operation in PSI5-P operation mode
‎2021-10-01 11:05 PM
L9663 only supports the "Master End". There are no "general purpose slave chips" that you can add your own sensors to. Not that I can find anywhere at least.
