VL6180X Sensor, device register memory volatility
dere1
Hi there,
I was wondering if the memory used to save the values in the device registers for the VL6180X sensor are volatile or non-volatile. This would affect how the sensors behaves during a power cycle. Could someone clarify this for me if possible?
Thanks in advance.
John E KVAM
You are correct. There is no volatile memory. At reboot, one loses the I2C address - if it was changed and one loses the calibration information. Restore that and you are good to go.
- john
If this or any post solves your issue, please mark them as 'Accept as Solution' It really helps. And if you notice anything wrong do not hesitate to 'Report Inappropriate Content'. Someone will review it.
Andrew Neil
The documentation would say what (if any) configuration is non-volatile.
If it's not mentioned, then assume it isn't.
Hi Andrew,
Thanks for the quick reply,
After a thorough look through the VL6180X datasheet I don't believe it mentions anything about the memory being non-volatile. I'll assume the device registers values are volatile.
John E KVAM
- john
