2023-08-08 01:14 PM
Been thru all the specs I can find on the VL53L5CX but I can't find how the Zones numbers map to array of distance_mm in the VL53L5CX_ResultsData struct.
Is Zone 0,0 distance_mm[0] please?
Or can someone point me to the spec/page please?
Many thanks IMK
2023-08-08 02:28 PM
The UM2974 seems to be dedicated to using examples like SimpleRanging and MultiSensorRanging, have you checked the available documents?
https://www.st.com/en/imaging-and-photonics-solutions/vl53l5cx.html#documentation
I don't know if it can help in your case, but I found these videos about advanced debugging:
2023-08-08 02:28 PM
