VL53L5CX Ultra Lite Driver (ULD) - Reflectance Value Format
‎2022-09-12 6:29 AM
I would need a technical information about VL53L5CX Ultra Lite Driver (ULD).
Specifically, what is the format of the reflectance value returned by the vl53l5cx_get_ranging_data() function?
I am supposing that the format is a percent value expressed as a decimal number limited to the range [0, 100].
However, in particular conditions, with high reflectivity targets, it happens that values above 100 (i.e. 127) are returned by the above function. How could be explained and handled correctly?
Furthermore, in vl53l5cx_api.c, the reflectance value is halved before being returned:
#ifndef VL53L5CX_DISABLE_REFLECTANCE_PERCENT
p_results->reflectance[i] /= (uint8_t)2;
#endif
This change appears to have been introduced from the release v.1.3.0.
Version : 1.3.0
Date : 02/11/2022
Comments :
- Corrected reflectance format (output divided by /2 vs previous driver version)
Could you elaborate on the subject?
Thank you
- Labels:
Time of flight
‎2022-09-12 7:27 AM
In the ULD, he reflectance is measured in percent where bright white paper is considered to be 100%
(Actually standard printer paper comes in at around 88%). So numbers above 100% are possible.
And it has a lot to do with if your target is specular (mirror-like) or Lamperatain (matte finish).
But it's best to use that number as a relitive value - it's how we order the strongest singal for instance.
- john
If this or any post solves your issue, please mark them as 'Accept as Solution' It really helps. And if you notice anything wrong do not hesitate to 'Report Inappropriate Content'. Someone will review it.
‎2022-09-12 7:27 AM
- john
‎2022-09-12 8:09 AM
Thank you John,
Your quick answer has been really appreciated.
I further investigated and now I have a better understood the definition of reflectance.
