VL53L5CX How can we place a VL53L5CX behind a glass- or plastic window? When we try this the sensor can only detect the window, and not what is outside the window.
RSive.1
1 REPLY 1
John E KVAM
Great question --
Start with the article:
https://community.st.com/s/article/Time-of-Flight-Cover-glass
(it's also in the article tab at the top of the ToF questions)
Your problem is called crosstalk - photons that hit the coverglass and reflect back.
you have 3 basic solutions:
1) clearer, thiner, optical quaility glass.
2) Separate glasses with an opaque barrier between them (Hormix.com.tw makes them)
3) crosstalk calibratrion.
Or I suppose you can use any combination of the above.
But start with the article and go from there.
  • john
Our community relies on fruitful exchanges and good quality content. You can thank and reward helpful and positive contributions by marking them as 'Accept as Solution'. When marking a solution, make sure it answers your original question or issue that you raised.
ST Employees that act as moderators have the right to accept the solution, judging by their expertise. This helps other community members identify useful discussions and refrain from raising the same question. If you notice any false behavior or abuse of the action, do not hesitate to 'Report Inappropriate Content'
