The 6180X is kind of robust but the most common issues are:
- Poor power.
- noise on the GPIO0 (Shutdown line) - this puts the sensor into reset and makes mess - a good sized pull-up is recommended.
- -miss-configured I2C. This is easy to do. Always check the status on all your calls. An i2C failure will show up as a timeout.
But do look at the chip, if it's running you will see the laser - unless you are a bit old. Then use a laptop camera to view the laser.
Good luck,
If this or any post solves your issue, please mark them as 'Accept as Solution' It really helps. And if you notice anything wrong do not hesitate to 'Report Inappropriate Content'. Someone will review it.
