2024-11-19 07:35 AM
I bought a STEVAL-55G0MBI1, which is the VD55G0 S-Board eval kit.
Trying to output the image to my PC, nothing is coming out.
What could be the issue with my setup?
2024-11-19 07:40 AM - edited 2024-11-19 08:42 AM
The cameras work - we've tested them. And PCs are pretty reliable.
That leaves the cable.
YOU NEED A USB C 3.1 CABLE.
Amazon.com has one described as:
for only $7.00
USB 3.2 works too.
The reason is that the older USB C cables are only rated to 480MBits per second. That's too slow for the next generation of cameras. USB 3.1 is 5Mbits and 3.2 is 10Mbits
for only $7.00
USB 3.2 works too.
