Laser TOF Sensor (VL53L1CXVOFY/1) power supply?
‎2021-08-30 02:23 AM
Hi, We are using Laser TOF Sensor (VL53L1CXVOFY/1) in one of our products.
Can we use AVDD=1.8V power supply? Even though AVDD = 2.8V, it looks like IOs will work on 1.8V.
- Labels:
Time of flight
‎2021-08-30 05:29 AM
Please follow the datasheet if you want the device to operate normally:
Table 14. Recommended operating conditions
2.6V < AVDD < 3.5V
‎2021-09-14 08:16 PM
Hi Mike,
If we connect AVDD (Pin 11) and AVDDVCSEL (Pin 1) to 2.8V, Are the IOs still operate on 1.8V mode as given in Datasheet page number 23, Table 14.
>The default driver mode is 1V8.
>2V8 mode is programmable using device settings loaded by the driver. For more details please refer to the
>VL53L1X API user manual (UM2356).
Regards,
Veera
‎2021-09-15 01:12 AM
Please check the datasheet, there are 2 modes, "standard mode" which is (1.8V) and 2V8 mode :
https://www.st.com/resource/en/datasheet/vl53l1x.pdf
Section 5.2:
