2022-03-09 05:15 AM
Inside this function I determined that the error is in inner function VL53L1_run_device_test. I can not find information about it. The PCB is wired correctly. There are interface pull-ups. Thanks.
2022-03-18 02:32 PM
This is a really odd one. A long time ago on the L0 we used to have the odd issue were the pre-programed RefSpad on a sensor was not close enough, and folks got this error. Try programming the RefSpad to 3 PRIOR to running the calibration. Does that pass?
