Hello everyone, I am trying to connect multiple VL53L5CX-SATEL sensors. I already managed to connect 3 sensors but when I add the fourth I lose tension in the SCL pin.
MBouj.11
1 REPLY 1
John E KVAM
It's a far too common problem, and it has nothing to do with what sensors you put on the I2C bus.
One has to size the pull-up on the SDA and SCL lines based on the number of sensors and the capacitance of the wire. And it's a real pain.
But NXP (who bought Philips) maintains a pretty good bit of documentation.
I2C-bus specification and user manual (nxp.com)
I think it's section 7 that explains the math to figure out what size pull-up you need.
Your MCU board manufacturer chose a value that's apparently good for 3 sensors, but after that, you need a bigger pullup.
Cheers,
  • john
If this or any post solves your issue, please mark them as 'Accept as Solution' It really helps. And if you notice anything wrong do not hesitate to 'Report Inappropriate Content'. Someone will review it.
