Anyone using VD6283 without stmcube ?
MZ68
Hi everybody, I'm trying to interface vd6283 (I own vd6283-satel breakout board) with other non-stm32 microcontrollers (esp32, samd21, ecc) .
stm's library (x-cube-als) claims that "should" be easy porting on another hw but...it's not that easy....
Did someone try to do that (even on a simple arduino r3) ?
Thanks!
Anne BIGOT
Sorry for this really late answer.
The VL6283 interface  is Arduino pins compatible but it is up to the user to provide an implementation of the platform-dependent components. This must be done complying with the definitions in STALS_platform.h
Our community relies on fruitful exchanges and good quality content. You can thank and reward helpful and positive contributions by marking them as 'Accept as Solution'. When marking a solution, make sure it answers your original question or issue that you raised.
ST Employees that act as moderators have the right to accept the solution, judging by their expertise. This helps other community members identify useful discussions and refrain from raising the same question. If you notice any false behavior or abuse of the action, do not hesitate to 'Report Inappropriate Content'
