2024-07-12 3:33 AM
Hello
I need to use full featured Teseo-Suite.
Sending letters to st-teseo-suite-support@st.com remain unanswered.
How could I obtain a full version of Teseo-Suite?
2024-07-12 7:53 AM
The key is machine-dependent and node locked.
Usually, it really only takes one working day to get another one, in the case of a holiday maybe a bit longer.
Good luck!
/Peter
2024-07-12 6:18 AM
Normally, the team responds within 24 hours, but I have asked again if a response is coming now. I'm definitely keeping my fingers crossed!
/Peter
2024-07-12 7:36 AM
So, it should be done, right?
2024-07-12 7:48 AM
Thanks for quick response.
Yes, I received avtivation key.
I have folowing question: can I reuse same key on diferrent computers, or should I request a new key each time?
2024-07-12 7:53 AM
Good luck!
/Peter
2025-02-06 1:14 AM
I have the same question and I had sent at least 3 emails for past few weeks.
Those emails remained unanswered.
Could you help me to check my activation request?
Thank you.
2025-02-06 1:58 AM
@yclin I'm sorry for the delay, but the email address st-teseo-suite-support@st.com is definitely the right one.
Please try again and also check your spam folder in case the reply has ended up there.
/Peter
2025-02-06 4:52 PM
I had send the email again, and I recieved following reply.
Also, all the previous request emails end up with this following reply. But there is no further response or receiving the activation key.
2025-02-07 12:56 AM
Hi @yclin,
I have checked with the team: a key has definitely been sent. You will receive a private message (PM) here shortly.
/Peter
