HI, For TESEOLIF3 Is there a way to get the constellation GST sentence is about ?
Xynium
5 REPLIES 5
Doesn't it provide detail via either the Talker ID or the SV numbering?
Francesco Virlinzi
Hi
You should enable it in the message-list.
The following script will enable the message GST and save the configuration.
$PSTMSETPAR,1201,0x8,1
$PSTMSAVEPAR
$PSTMSRR
Francesco
Xynium
I already have GST in the nmea list.
I mean i want a gst report for each constellation in use (residue or error)
I got GPGST but i suppose this error evaluation (noise) is not made only for GPS
I should have a GLGST and a GAGST
JP
Francesco Virlinzi
Hi
In the Teseo3 solution (ICs and Modules) 'GPGST' you will always get 'GP' prefix whatever the constellations enabled because the reported values are related to the unique PVT solution.
Francesco
Xynium
Ok
