2023-08-04 02:41 AM
I have registered and validated my email, got as farr as choosing a password but then an error happened. Help please
2024-02-09 08:47 AM
Lina,
I am on https://my.st.com/stparc
I can enter my username and password and then when I click enter I get to the screen noted previously.
Thank you in advance for any help on this.
2024-02-27 01:40 PM
2024-02-28 01:59 AM
Hello @mzimmer ,
Thanks for clarifying. I am checking this case internally and I will inform you once I get some news.
Lina
2024-02-28 07:33 AM
Hello @mzimmer ,
I have an update here.
That link (https://my.st.com/stparc) you are trying to get to is called the Vendor Portal for things like invoices for work done for ST.
They shared the attached handout showing where to register (separate from just a standard myST account) and most importantly it shows their direct email address as well, which is: apitaly.esas@st.com.
Please check the manual and contact the team directly if necessary.
Let me know if it helps,
Lina
2024-03-07 04:52 AM
Hi Lina
I have access to the portal now. Thank you.
