'Kudos' button broken
Andrew Neil
I get this error when I press the 'Kudos' button:
https://community.st.com/t5/stm32-mcus-products/stm32g411-availability/m-p/885372/highlight/true#M293512
Also happens on other posts in that thread, and in other threads.
Looks like a recurrence of Kudos button gives error (12 Dec 2025)
34 REPLIES 34
No, it's not working here.
@Andrew Neil , we've got informed the changes will be live next week, on 9th April after all. Apologies for the last minute delay.
Also doesn't work for me.
Kudo posts if you have the same problem and kudo replies if the solution works.
Click "Accept as Solution" if a reply solved your problem. If no solution was posted please answer with your own.
Andrew Neil
Must be working for some - but not me & @unsigned_char_array,  (at least):
Now it works for me again.
me too (for now...)
This feature is up & down like a yo-yo !
I spoke too soon  - it's broken again!
I try giving a kudo in now, work correctly for me.
Lina_DABASINSKAITE
Community manager
Hi all,
The issue has been fixed, and kudo button should work as expected. Please check on your end and let me know if it works or you still face issues.
Thanks,
Lina
It is working at the moment ...
Also pasting images ... ?
