2024-09-30 9:06 AM
I am currently working on validating a machine learning model that I have deployed on an STM32 microcontroller. While the model successfully runs on the STM32, the results it produces differ significantly from those obtained when running the model on a computer.
Additionally, when I attempt to perform validation on a desktop environment, I encounter the following error:
E103(CliRuntimeError): Unable to generate the "libai_network" library.
Since the website could not accept the .tflite file, I have attached the picture of the structure of the model. The model was trained using TensorFlow 2.17 and utilizes approximately 75KB of flash memory and 15KB of RAM.
I would greatly appreciate any guidance or assistance in resolving these issues.
Thank you!
2024-10-07 12:43 AM
I have correct inference loop on my side with this project, could you please give it a shot and see if it is ok on your side?
Could you also share with us what is your version of STM32CubeMX ?
