Support for autogenerated code by STM32Cube.AI
‎2019-07-24 3:01 AM
Good morning,
I have created a project with CubeMX.AI based on an .h5 file constructed in keras following the steps shown on ST tutorial
https://www.youtube.com/watch?v=grgNXdkmzzQ (Getting Started with STM32Cube.AI).
Is it possibile to have an example showing how to exploit the generated code in order to solve
a generic problem of classification for a new sample of data?
Best regards
‎2019-08-06 12:39 AM
Did you find answer to this question?I am also looking for the same.
‎2019-08-06 6:17 AM
If you're looking for an example of code using X-Cube-AI for a custom project you can check this GitHub link:
https://github.com/ROC5COR/HousePricePredictionOnSTM32
This project uses an old version of X-Cube-AI v3.3.0 but the idea is here.
However the project is not a classification but a regression problem (House prices prediction) but you can just get rid of the output prediction and use a threshold to make it a classification problem with your own NN
Hope this can help you :)
Romain
