STM32H747 Person Detect FP-AI-VISION1 Camera Problem
‎2023-12-19 05:08 AM - edited ‎2023-12-20 12:31 AM
I'm working on artificial intelligence on STM32H747. I started my work with projects on FP-AI-VISION. First, I solved the display problem caused by NT35510 and tried the project again. When I tried it, I got the look in the first photo. At first I couldn't understand what was happening because I thought the problem would be solved when I fixed the screen. Afterwards, I debugged the code and saw that the BSP_CAMERA_INIT function branched to Error Handler. I looked into what error message I was getting and saw that I was getting the BSP_ERROW_UNKNOWN_COMPONENT error. How can I solve this problem? I just unpacked the camera so I hardly find the risk of the camera getting a hardware fault. Do I need any extra action to operate the camera?
Best Regards,
Bedirhan Köksoy
I
‎2024-01-26 03:59 AM
Update,
It didn't work only because we encountered a hardware problem with the camera. We replaced the camera and now we can continue our work properly. Thanks for all your answers.
‎2023-12-20 12:38 AM - edited ‎2023-12-20 12:38 AM
@KDJEM.1 @Tesla DeLorean could you help me?
‎2023-12-20 04:30 AM
Hello @koksoybedirhan ,
Thank you for bringing this issue to our attention.
I reported this problem internally.
Internal ticket number: 169297 (This is an internal tracking number and is not accessible or usable by customers)"
Thank you.
Kaouthar
‎2023-12-25 01:28 AM
Could someone give any information?
‎2023-12-25 02:42 AM
The BSP_ERROW_UNKNOWN_COMPONENT can happen if the camera is not detected. It might be due either to a wrong connection or a malfunction of the camera board.
Be sure to plug and unplug the camera board while the board is not powered. A short-circuit can happen otherwise.
You can check the LED status on the camera board too.
To double check the fix on the display, you can refer to the Wiki here:
AI:How to use transfer learning to perform image classification on STM32 - stm32mcu
or
AI:How to use Teachable Machine to create an image classification application on STM32 - stm32mcu
Update,
