2025-03-13 9:24 PM - last edited on 2025-03-14 1:37 AM by mƎALLEm
Every time I click on the AI model, my clock tree is forcibly changed, and the external clock is also changed for me.
2025-03-13 11:35 PM - last edited on 2025-03-14 1:38 AM by mƎALLEm
Has no one encountered this problem? Is there no expert using this thing?
2025-03-14 1:19 AM
Yes some parameters are defined as "required" and they apply at X-CUBE-AI launch.
The prompt you saw is only about "optimal parameters".
If you want to disable this behavior, here is the following:
- Open $HOME\STM32Cube\Repository\Packs\STMicroelectronics\X-CUBE-AI\10.0.0\db\boardExternalMem.xml (Windows HOME equivalent is C:\Users\<username>)
- Find your Discovery Kit board or your Die ID (Example: STM32F746G-DISCO is die 0x449)
- Remove or comment the lines in object "requiredParameters"
Best regards,
Yanis
