2023-05-03 03:51 PM
2023-05-04 12:55 AM
Is it possible to have more details? Is it a ONNX model? X-CUBE-AI version?
The input tensor is a 4d tensor, if we not consider the batch dimension. what is the type of the operator in relation with this input tensor?
br,
JM
2023-05-04 03:40 AM
Thanks for your help!.
I generate the files by converting ". H5 file" (using keras, tensorflow) using CUBEMX, the shape of the tensors was correct in this step after the generation of files (network.c,...), I realize that my input shape which declared in python was (Batch, Depth, Height, width, Channel) :(1, 7,6,6,1)was inverted to ( 1,6,6,7,1).
All tensors in the model were inverted. I tried to manually change the shape of the tensors in network.c but it causes errors in the model creation.
