Errors Analyzing ONNX Models in X-Cube-AI Tool
segamar
Hello everyone:
         I encountered a problem when importing the ONNX model and using the X CUDE AI tool for analysis. I have tried many solutions but couldn't solve it. I hope someone here can help me. The specific problem is as follows:
      ST Edge AI Core v1.0.0-19894
      NOT IMPLEMENTED: Only step=1 is supported for each axis: [2]
        This is a problem that occurred after adding the SPDConv module to the YOLOv5 model. Before that, the model could be imported and analyzed smoothly.
3 REPLIES 3
Julian E.
Hello @segamar ,
In the zip, this is the non SPDversions?
The ST Edge AI (behind cubeAI) is supporting the spaceToDepth for onnx so there should not be an issue.
https://stedgeai-dc.st.com/assets/embedded-docs/supported_ops_onnx.html
Could you upload the onnx model that does not work please.
Julian
I uploaded the ONNX file that contained SPDConv, but I also uploaded a new ONNX file that didn't work.
Thank you for your help
Julian E.
Hello @segamar ,
Your last model goes through the last version of st edge ai without any issue: ST Edge AI Core v10.0.0-20047
STEdgeAI-Core - Artificial intelligence (AI) optimizer technology for STMicroelectronics products - STMicroelectronics
Have a good day,
Julian
